Encor une erreur. en 1.3b2
wawa_1
sam. mars 09, 2013 9:42 am
Bonjour, voila un petit problem survenu hier:
Erreur de mise à jour des colonnes
java.lang.ArrayIndexOutOfBoundsException: -1
org.openconcerto.utils.ExceptionHandler: Erreur de mise à jour des colonnes
at org.openconcerto.sql.view.column.ColumnPanel$5.done(ColumnPanel.java:222)
at org.openconcerto.utils.SwingWorker2$5.run(SwingWorker2.java:536)
at org.openconcerto.utils.SwingWorker2$DoSubmitAccumulativeRunnable.run(SwingWorker2.java:619)
at
org.openconcerto.utils.SwingWorker2$DoSubmitAccumulativeRunnable.actionPerformed(SwingWorker2.java:631)
Caused by: java.util.concurrent.ExecutionException: java.lang.ArrayIndexOutOfBoundsException: -1
at java.util.concurrent.FutureTask$Sync.innerGet(Unknown Source)
at org.openconcerto.utils.SwingWorker2.get(SwingWorker2.java:412)
at org.openconcerto.sql.view.column.ColumnPanel$5.done(ColumnPanel.java:217)
... 20 more
Caused by: java.lang.ArrayIndexOutOfBoundsException: -1
at java.util.ArrayList.elementData(Unknown Source)
at java.util.ArrayList.get(Unknown Source)
at org.openconcerto.sql.view.column.ColumnPanelFetcher.fetch(ColumnPanelFetcher.java:134)
at org.openconcerto.sql.view.column.ColumnPanelFetcher.getRowsForColumn(ColumnPanelFetcher.java:73)
at org.openconcerto.sql.view.column.ColumnPanel$5.doInBackground(ColumnPanel.java:202)
at org.openconcerto.sql.view.column.ColumnPanel$5.doInBackground(ColumnPanel.java:1)
at org.openconcerto.utils.SwingWorker2$1.call(SwingWorker2.java:115)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at org.openconcerto.utils.SwingWorker2.run(SwingWorker2.java:163)
Merci pour votre aide et bon week-end.
lun. mars 11, 2013 11:54 am
Bug corrigé. On approche d'une beta 3 stable.
wawa_1
lun. mars 11, 2013 6:15 pm
si j'ai pus vous rendre service..
cordialement
