Echec mise à jour 1.3
zarlab
jeu. déc. 27, 2012 2:57 pm
Il m'est impossible de mettre ma base à jour... J'obtiens ce message :
Echec de mise à jour
Impossible d'accéder au résultat de DELETE FROM "OpenConcerto"."Common"."SOCIETE_COMMON" WHERE "SOCIETE_COMMON"."ID" BETWEEN 43 AND 47
 in jdbc:h2:file:/home/zarlabien/Doc/DBData/OpenConcerto
	at org.openconcerto.erp.config.InstallationPanel$1$1.run(InstallationPanel.java:281)
	at java.lang.Thread.run(Thread.java:679)
Caused by: java.lang.IllegalStateException: Impossible d'accéder au résultat de DELETE FROM "OpenConcerto"."Common"."SOCIETE_COMMON" WHERE "SOCIETE_COMMON"."ID" BETWEEN 43 AND 47
 in jdbc:h2:file:/home/zarlabien/Dropbox/DBData/OpenConcerto
	at org.openconcerto.sql.model.SQLDataSource.execute(SQLDataSource.java:492)
	at org.openconcerto.sql.model.SQLDataSource.execute(SQLDataSource.java:407)
	at org.openconcerto.sql.model.SQLDataSource.execute(SQLDataSource.java:387)
	at org.openconcerto.sql.model.SQLDataSource.execute(SQLDataSource.java:316)
	at org.openconcerto.erp.config.InstallationPanel.updateCommon(InstallationPanel.java:2065)
	at org.openconcerto.erp.config.InstallationPanel.access$4(InstallationPanel.java:2059)
	at org.openconcerto.erp.config.InstallationPanel$1$1.run(InstallationPanel.java:259)
Caused by: java.sql.SQLException: second exec failed: Referential integrity constraint violation: "EXERCICE_COMMON_ID_SOCIETE_COMMON_fkey: ""Common"".EXERCICE_COMMON FOREIGN KEY(ID_SOCIETE_COMMON) REFERENCES ""Common"".SOCIETE_COMMON(ID) (47)"; SQL statement:
DELETE FROM "OpenConcerto"."Common"."SOCIETE_COMMON" WHERE "SOCIETE_COMMON"."ID" BETWEEN 43 AND 47 [23503-168]
	at org.openconcerto.sql.model.SQLDataSource.executeTwice(SQLDataSource.java:782)
	at org.openconcerto.sql.model.SQLDataSource.execute(SQLDataSource.java:458)
	... 7 more
Caused by: org.h2.jdbc.JdbcSQLException: Referential integrity constraint violation: "EXERCICE_COMMON_ID_SOCIETE_COMMON_fkey: ""Common"".EXERCICE_COMMON FOREIGN KEY(ID_SOCIETE_COMMON) REFERENCES ""Common"".SOCIETE_COMMON(ID) (47)"; SQL statement:
	at org.h2.message.DbException.getJdbcSQLException(DbException.java:329)
	at org.h2.message.DbException.get(DbException.java:169)
	at org.h2.message.DbException.get(DbException.java:146)
	at org.h2.constraint.ConstraintReferential.checkRow(ConstraintReferential.java:414)
	at org.h2.constraint.ConstraintReferential.checkRowRefTable(ConstraintReferential.java:431)
	at org.h2.constraint.ConstraintReferential.checkRow(ConstraintReferential.java:307)
	at org.h2.table.Table.fireConstraints(Table.java:871)
	at org.h2.table.Table.fireAfterRow(Table.java:888)
	at org.h2.command.dml.Delete.update(Delete.java:99)
	at org.h2.command.CommandContainer.update(CommandContainer.java:75)
	at org.h2.command.Command.executeUpdate(Command.java:230)
	at org.h2.jdbc.JdbcStatement.executeUpdateInternal(JdbcStatement.java:125)
	at org.h2.jdbc.JdbcStatement.executeUpdate(JdbcStatement.java:732)
	at org.apache.commons.dbcp.DelegatingStatement.executeUpdate(DelegatingStatement.java:321)
	at org.openconcerto.sql.model.SQLDataSource.execute(SQLDataSource.java:856)
	at org.openconcerto.sql.model.SQLDataSource.executeOnce(SQLDataSource.java:792)
	at org.openconcerto.sql.model.SQLDataSource.executeTwice(SQLDataSource.java:761)
	... 8 more
Ma base est elle "corrompue"? Est ce grave? Comment réparer?
(Je suis sous Linux Mint 13 / Java 7 / OC monoposte)
ven. déc. 28, 2012 4:04 pm
N'hésitez pas à nous envoyer votre base, ce problème est intéressant.
zarlab
jeu. janv. 03, 2013 4:09 pm
Bonjour, je vous ai envoyé la base sur info@ilm-informatique...
cece2607
jeu. janv. 17, 2013 7:46 pm
J'ai exactement le même problème, pourriez-vous me dire comment résoudre ce problème?
ven. janv. 18, 2013 10:58 am
Il faudra attendre la prochaine béta, elle permettra de migrer les cas un peu "spéciaux" :(
