Erreur lors de la création d'articles
sylco
mer. juin 08, 2022 12:15 pm
Bonjour, je débute sous OC.
J'ai une erreur qui apparaît lorsque je crée mon premier article au moment de taper le prix d'achat:
Invalid location
	at java.base/java.lang.ThreadGroup.uncaughtException(ThreadGroup.java:1055)
	at java.base/java.lang.ThreadGroup.uncaughtException(ThreadGroup.java:1050)
	at java.desktop/java.awt.EventDispatchThread.processException(EventDispatchThread.java:222)
	at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:214)
	at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:124)
	at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:113)
	at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:109)
	at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
	at java.desktop/java.awt.EventDispatchThread.run(EventDispatchThread.java:90)
Caused by: java.lang.IllegalArgumentException: Invalid location
	at java.desktop/javax.swing.text.JTextComponent.getSelectedText(JTextComponent.java:1784)
	at java.desktop/javax.swing.text.DefaultCaret.updateSystemSelection(DefaultCaret.java:1360)
	at java.desktop/javax.swing.text.DefaultCaret.focusGained(DefaultCaret.java:355)
	at com.formdev.flatlaf.ui.FlatCaret.focusGained(FlatCaret.java:71)
	at java.desktop/java.awt.AWTEventMulticaster.focusGained(AWTEventMulticaster.java:228)
	at java.desktop/java.awt.AWTEventMulticaster.focusGained(AWTEventMulticaster.java:227)
	at java.desktop/java.awt.Component.processFocusEvent(Component.java:6524)
	at java.desktop/java.awt.Component.processEvent(Component.java:6391)
	at java.desktop/java.awt.Container.processEvent(Container.java:2263)
	at java.desktop/java.awt.Component.dispatchEventImpl(Component.java:5011)
	at java.desktop/java.awt.Container.dispatchEventImpl(Container.java:2321)
	at java.desktop/java.awt.Component.dispatchEvent(Component.java:4843)
	at java.desktop/java.awt.KeyboardFocusManager.redispatchEvent(KeyboardFocusManager.java:1950)
	at java.desktop/java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(DefaultKeyboardFocusManager.java:1050)
	at java.desktop/java.awt.DefaultKeyboardFocusManager.dispatchEvent(DefaultKeyboardFocusManager.java:674)
	at java.desktop/java.awt.Component.dispatchEventImpl(Component.java:4892)
	at java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:772)
	at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:721)
	at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:715)
	at java.base/java.security.AccessController.doPrivileged(Native Method)
	at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:85)
	at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:95)
	at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:745)
	at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:743)
	at java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:742)
	at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:203)
	... 5 more
Qu'est ce que j'ai mal fait?
Sylvain
mer. juin 08, 2022 1:53 pm
Il s'agit d'un bug externe à OpenConcerto, vous pouvez le contourner
en changeant de "look and feel" dans les préférences.
sylco
mer. juin 08, 2022 5:27 pm
Bonsoir, merci pour votre réponse.
J'ai essayé avec nimbus et flat mais c'est toujours pareil
