BuG OP 1.7
Jérôme
ven. avr. 23, 2021 12:28 pm
D'abord, merci pour cette mise à jour d'OP.
Mon thème est le Flat, et lorsque je veux désélectionner l'affichage de colonnes dans une fenêtre (exemple, je veux enlever "Référence"), alors j'ai un message d'erreur qui ne s'arrête jamais, je dois "killer" le logiciel!
Je suis sur Linux Mint 20.1.
Avez vous me idée?
Index -1 out of bounds for length 20
at org.openconcerto.utils.ExceptionHandler.handle(ExceptionHandler.java:145)
at org.openconcerto.utils.ExceptionHandler.handle(ExceptionHandler.java:152)
at java.base/java.lang.ThreadGroup.uncaughtException(ThreadGroup.java:1055)
at java.base/java.lang.ThreadGroup.uncaughtException(ThreadGroup.java:1050)
at java.desktop/java.awt.EventDispatchThread.processException(EventDispatchThread.java:222)
at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:214)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:124)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:113)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:109)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.desktop/java.awt.EventDispatchThread.run(EventDispatchThread.java:90)
Caused by: java.lang.ArrayIndexOutOfBoundsException: Index -1 out of bounds for length 20
at java.base/java.util.Vector.elementData(Vector.java:762)
at java.base/java.util.Vector.elementAt(Vector.java:500)
at java.desktop/javax.swing.table.DefaultTableColumnModel.getColumn(DefaultTableColumnModel.java:295)
at java.desktop/javax.swing.plaf.basic.BasicTableHeaderUI.getHeaderRenderer(BasicTableHeaderUI.java:716)
at java.desktop/javax.swing.plaf.basic.BasicTableHeaderUI.paintCell(BasicTableHeaderUI.java:732)
at java.desktop/javax.swing.plaf.basic.BasicTableHeaderUI.paint(BasicTableHeaderUI.java:708)
at com.formdev.flatlaf.ui.FlatTableHeaderUI.paint(FlatTableHeaderUI.java:122)
at java.desktop/javax.swing.plaf.ComponentUI.update(ComponentUI.java:161)
at java.desktop/javax.swing.JComponent.paintComponent(JComponent.java:797)
at java.desktop/javax.swing.JComponent.paint(JComponent.java:1074)
at java.desktop/javax.swing.JComponent.paintToOffscreen(JComponent.java:5255)
at java.desktop/javax.swing.BufferStrategyPaintManager.paint(BufferStrategyPaintManager.java:246)
at java.desktop/javax.swing.RepaintManager.paint(RepaintManager.java:1323)
at java.desktop/javax.swing.JComponent._paintImmediately(JComponent.java:5203)
at java.desktop/javax.swing.JComponent.paintImmediately(JComponent.java:5013)
at java.desktop/javax.swing.RepaintManager$4.run(RepaintManager.java:865)
at java.desktop/javax.swing.RepaintManager$4.run(RepaintManager.java:848)
at java.base/java.security.AccessController.doPrivileged(Native Method)
at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:85)
at java.desktop/javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:848)
at java.desktop/javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:823)
at java.desktop/javax.swing.RepaintManager.prePaintDirtyRegions(RepaintManager.java:772)
at java.desktop/javax.swing.RepaintManager$ProcessingRunnable.run(RepaintManager.java:1890)
at java.desktop/java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:313)
at java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:770)
at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:721)
at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:715)
at java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:740)
at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:203)
... 5 more
ven. avr. 23, 2021 2:29 pm
Je viens de faire le test, aucune erreur à l'horizon.
Vérifiez votre version de Java.
Jérôme
sam. avr. 24, 2021 6:26 am
Je viens de vérifier, cela ce produit uniquement avec le thème FLAT!
Version de java:
openjdk version "11.0.10" 2021-01-19
OpenJDK Runtime Environment (build 11.0.10+9-Ubuntu-0ubuntu1.20.04)
OpenJDK 64-Bit Server VM (build 11.0.10+9-Ubuntu-0ubuntu1.20.04, mixed mode, sharing)
Pouvez vous reproduire?
sam. avr. 24, 2021 1:56 pm
Je viens de tester sur Windows 10, AdoptOpenJDK 11.0.11
Le bug n'apparait pas.
Donc soit un bug linux soit un bug openjdk.
