bug configuration logiciel
Claisse
mar. juil. 02, 2019 2:08 pm
Je suis débutante avec OPENCONCERTO et depuis 1 semaine j'ai des messages d'erreurs qui apparaissent quelque soit la manipulation.
Exemples :
- le numéro de facture client reste bloqué sur le même chiffre
- impossible de mettre à jour les stock manuellement
- émission de la facture client ne fait pas bougé les stock
Voilà le message :
Update error
Impossible d'accéder au résultat de SELECT "MOUVEMENT_STOCK"."ID", "MOUVEMENT_STOCK"."QTE", "MOUVEMENT_STOCK"."REEL", "MOUVEMENT_STOCK"."ID_ARTICLE", "tAlias__ID_ARTICLE__ARTICLE"."ID", "tAlias__ID_ARTICLE__ARTICLE"."ID_STOCK", "tAlias__ID_ARTICLE__ID_STOCK__STOCK"."ID", "tAlias__ID_ARTICLE__ID_STOCK__STOCK"."QTE_REEL", "tAlias__ID_ARTICLE__ID_STOCK__STOCK"."QTE_TH", "tAlias__ID_ARTICLE__ID_STOCK__STOCK"."QTE_RECEPT_ATTENTE", "tAlias__ID_ARTICLE__ID_STOCK__STOCK"."QTE_LIV_ATTENTE"
FROM "OpenConcerto"."OpenConcerto42"."MOUVEMENT_STOCK"
LEFT JOIN "OpenConcerto"."OpenConcerto42"."ARTICLE" "tAlias__ID_ARTICLE__ARTICLE" on (("MOUVEMENT_STOCK"."ID_ARTICLE" = "tAlias__ID_ARTICLE__ARTICLE"."ID") AND ("tAlias__ID_ARTICLE__ARTICLE"."ARCHIVE" = 0)) AND ("tAlias__ID_ARTICLE__ARTICLE"."ID" <> 1)
LEFT JOIN "OpenConcerto"."OpenConcerto42"."STOCK" "tAlias__ID_ARTICLE__ID_STOCK__STOCK" on (("tAlias__ID_ARTICLE__ARTICLE"."ID_STOCK" = "tAlias__ID_ARTICLE__ID_STOCK__STOCK"."ID") AND ("tAlias__ID_ARTICLE__ID_STOCK__STOCK"."ARCHIVE" = 0)) AND ("tAlias__ID_ARTICLE__ID_STOCK__STOCK"."ID" <> 1)
WHERE ("MOUVEMENT_STOCK"."ID" <> 1) AND (("MOUVEMENT_STOCK"."ARCHIVE" = 0) AND (("MOUVEMENT_STOCK"."SOURCE" = 'BON_RECEPTION') AND ("MOUVEMENT_STOCK"."IDSOURCE" = 29)))
ORDER BY "MOUVEMENT_STOCK"."ORDRE"
in jdbc:h2:file:C:\Users\AFR Conseils\.java\ilm\sql-config\OpenConcerto\DBData/OpenConcerto
org.openconcerto.utils.ExceptionHandler: Update error
at org.openconcerto.erp.core.supplychain.receipt.component.BonReceptionSQLComponent$5.run(BonReceptionSQLComponent.java:406)
Caused by: java.lang.IllegalStateException: Impossible d'accéder au résultat de SELECT "MOUVEMENT_STOCK"."ID", "MOUVEMENT_STOCK"."QTE", "MOUVEMENT_STOCK"."REEL", "MOUVEMENT_STOCK"."ID_ARTICLE", "tAlias__ID_ARTICLE__ARTICLE"."ID", "tAlias__ID_ARTICLE__ARTICLE"."ID_STOCK", "tAlias__ID_ARTICLE__ID_STOCK__STOCK"."ID", "tAlias__ID_ARTICLE__ID_STOCK__STOCK"."QTE_REEL", "tAlias__ID_ARTICLE__ID_STOCK__STOCK"."QTE_TH", "tAlias__ID_ARTICLE__ID_STOCK__STOCK"."QTE_RECEPT_ATTENTE", "tAlias__ID_ARTICLE__ID_STOCK__STOCK"."QTE_LIV_ATTENTE"
at org.openconcerto.sql.model.SQLDataSource.execute(SQLDataSource.java:640)
at org.openconcerto.sql.model.SQLDataSource.execute(SQLDataSource.java:545)
at org.openconcerto.sql.model.SQLRowValuesListFetcher.fetch(SQLRowValuesListFetcher.java:1217)
at org.openconcerto.sql.model.SQLRowValuesListFetcher.fetch(SQLRowValuesListFetcher.java:1150)
at org.openconcerto.sql.model.SQLRowValuesListFetcher.fetch(SQLRowValuesListFetcher.java:1132)
at org.openconcerto.sql.model.SQLRowValuesListFetcher.fetch(SQLRowValuesListFetcher.java:1091)
at org.openconcerto.erp.core.supplychain.stock.element.StockItemsUpdater.clearExistingMvt(StockItemsUpdater.java:224)
at org.openconcerto.erp.core.supplychain.stock.element.StockItemsUpdater.update(StockItemsUpdater.java:118)
at org.openconcerto.erp.core.supplychain.receipt.component.BonReceptionSQLComponent.updateStock(BonReceptionSQLComponent.java:597)
at org.openconcerto.erp.core.supplychain.receipt.component.BonReceptionSQLComponent.access$3(BonReceptionSQLComponent.java:577)
at org.openconcerto.erp.core.supplychain.receipt.component.BonReceptionSQLComponent$5.run(BonReceptionSQLComponent.java:404)
... 3 more
Caused by: java.sql.SQLException: second exec failed: General error: "java.lang.ArrayIndexOutOfBoundsException: 0"; SQL statement:
ORDER BY "MOUVEMENT_STOCK"."ORDRE" [50000-175]
at org.openconcerto.sql.model.SQLDataSource.executeTwice(SQLDataSource.java:965)
at org.openconcerto.sql.model.SQLDataSource.execute(SQLDataSource.java:608)
... 13 more
Caused by: org.h2.jdbc.JdbcSQLException: General error: "java.lang.ArrayIndexOutOfBoundsException: 0"; SQL statement:
at org.h2.command.Command.executeQuery(Command.java:208)
at org.h2.jdbc.JdbcStatement.executeInternal(JdbcStatement.java:177)
at org.openconcerto.sql.model.SQLDataSource$ExecutorThread.run(SQLDataSource.java:1157)
Caused by: java.lang.ArrayIndexOutOfBoundsException: 0
at org.h2.index.PageDataLeaf.getRowAt(PageDataLeaf.java:329)
at org.h2.index.PageDataCursor.nextRow(PageDataCursor.java:100)
at org.h2.index.IndexCursor.next(IndexCursor.java:274)
at org.h2.table.TableFilter.next(TableFilter.java:359)
at org.h2.command.dml.Select.queryFlat(Select.java:527)
at org.h2.command.dml.Select.queryWithoutCache(Select.java:632)
at org.h2.command.dml.Query.query(Query.java:314)
at org.h2.command.dml.Query.query(Query.java:284)
at org.h2.command.dml.Query.query(Query.java:36)
at org.h2.command.CommandContainer.query(CommandContainer.java:91)
at org.h2.command.Command.executeQuery(Command.java:196)
... 4 more
Merci d'avance pour votre aide
mar. juil. 02, 2019 3:59 pm
Il y a un problème sur votre fichier de base de données, généralement causé par une coupure du PC lors de l'utilisation d'OpenConcerto.
Restaurez depuis une sauvegarde ou contacter ILM pour réparation du fichier.
Claisse
mar. juil. 02, 2019 4:08 pm
Merci beaucoup pour votre réponse
Où vais je trouver dois chercher la sauvegarde ?
Claisse
mar. juil. 02, 2019 4:13 pm
Est ce que c'est un fichier zip qui s'appelle base ?
Sebiiiii
mer. juil. 03, 2019 7:31 am
oui
HDDR49.fr
Claisse
mer. juil. 03, 2019 7:40 am
Merci beaucoup
Bonne journée
STOUFFE
mer. févr. 05, 2020 8:38 pm
Bonsoir Claisse,
Avez-vous pu corrigé votre soucis et avec combien de jetons ?
J'ai exactement le même message d'erreur avec en plus les modifications de mes factures qui ne sont plus pris en compte a l'impression ?
Merci à vous ;)
