Erreurs d'injection SQL OpenConcerto v1.1
Raphux
sam. oct. 15, 2011 4:35 pm
Hello,
je rencontre quelques erreurs lors de l'installation de la version multiposte sur postgres.
Tout d'abord, voici comment j'ai préparé le socle :
briareos2 ~ # su - postgres
postgres@briareos2 ~ $ createuser -D -S -R openconcerto
postgres@briareos2 ~ $ createdb -O openconcerto  "OpenConcerto"
postgres@briareos2 ~ $ md5sum /home/raphux/utils/OpenConcerto/openconcerto.sql
3821b38a554ab4cf90a97ad8edc973ad  /home/raphux/utils/OpenConcerto/openconcerto.sql
Si j'injecte le fichier tel quel, voici ce que ça donne :
postgres@briareos2 ~ $ psql -h localhost -U openconcerto -f /home/raphux/utils/OpenConcerto/openconcerto.sql OpenConcerto
psql:/home/raphux/utils/OpenConcerto/openconcerto.sql:3: ERROR:  syntax error at or near ""
LINE 1: CREATE SCHEMA "Common";
psql:/home/raphux/utils/OpenConcerto/openconcerto.sql:6: ERROR:  schema "Common" does not exist
psql:/home/raphux/utils/OpenConcerto/openconcerto.sql:14: ERROR:  schema "Common" does not exist
CREATE SCHEMA
ALTER SCHEMA
COMMENT
CREATE SCHEMA
ALTER SCHEMA
CREATE SCHEMA
ALTER SCHEMA
SET
psql:/home/raphux/utils/OpenConcerto/openconcerto.sql:66: ERROR:  relation "ordret_generator" does not exist
LINE 3:     AS $$ UPDATE ordreT_generator set tmpVal = currentVal, c...
psql:/home/raphux/utils/OpenConcerto/openconcerto.sql:69: ERROR:  function Default.next_ordret() does not exist
psql:/home/raphux/utils/OpenConcerto/openconcerto.sql:79: ERROR:  relation "ordret_generator" does not exist
LINE 3:     AS $$ update ordreT_generator set currentVal = minVal ;s...
psql:/home/raphux/utils/OpenConcerto/openconcerto.sql:82: ERROR:  function Default.reset_ordret() does not exist
psql:/home/raphux/utils/OpenConcerto/openconcerto.sql:84: ERROR:  invalid value for parameter "search_path": ""Common", pg_catalog"
DETAIL:  schema "Common" does not exist
SET
SET
CREATE TABLE
psql:/home/raphux/utils/OpenConcerto/openconcerto.sql:105: ERROR:  schema "Common" does not exist
CREATE SEQUENCE
psql:/home/raphux/utils/OpenConcerto/openconcerto.sql:121: ERROR:  schema "Common" does not exist
ALTER SEQUENCE
 setval
      1
(1 row)
Le message se répète à longueur de temps parce qu'il y a eu un problème au début de l'injection.
En fait, il y a un caractère invisible foireux au début du fichier SQL :
postgres@briareos2 ~ $ cat -e /home/raphux/utils/OpenConcerto/openconcerto.sql | head
M-oM-;M-?CREATE SCHEMA "Common";$
ALTER SCHEMA "Common" OWNER TO openconcerto;$
-- TOC entry 12263 (class 0 OID 0)$
-- Dependencies: 6$
-- Name: SCHEMA "Common"; Type: COMMENT; Schema: -; Owner: openconcerto$
C'est à cause de ça que postgres beugle lors de l'injection.
Si je corrige le fichier, voici le diff (évidement, le changement n'est pas visible, mais est bien détectable) :
raphux@briareos2 ~/utils/OpenConcerto $ diff -Nau openconcerto.sql-bad openconcerto.sql
--- openconcerto.sql-bad	2011-05-26 18:31:16.000000000 +0200
+++ openconcerto.sql	2011-10-15 18:01:36.000000000 +0200
@@ -1,4 +1,4 @@
-CREATE SCHEMA "Common";
+CREATE SCHEMA "Common";
Mais plus visible en utilisant cat -e comme précédemment :
raphux@briareos2 ~/utils/OpenConcerto $ cat -e openconcerto.sql | head
-- Dependencies: 6$
C'est tout de suite beaucoup mieux, mais il reste ce problème de «relation» :
postgres@briareos2 ~ $ dropdb "OpenConcerto" && dropuser openconcerto
postgres@briareos2 ~ $ createuser -D -S -R openconcerto && createdb -O openconcerto  "OpenConcerto"
CREATE SCHEMA
ALTER SCHEMA
COMMENT
CREATE SCHEMA
ALTER SCHEMA
COMMENT
CREATE SCHEMA
ALTER SCHEMA
CREATE SCHEMA
ALTER SCHEMA
SET
psql:/home/raphux/utils/OpenConcerto/openconcerto.sql:64: ERROR:  relation "ordret_generator" does not exist
psql:/home/raphux/utils/OpenConcerto/openconcerto.sql:67: ERROR:  function Default.next_ordret() does not exist
psql:/home/raphux/utils/OpenConcerto/openconcerto.sql:77: ERROR:  relation "ordret_generator" does not exist
psql:/home/raphux/utils/OpenConcerto/openconcerto.sql:80: ERROR:  function Default.reset_ordret() does not exist
SET
SET
SET
CREATE TABLE
ALTER TABLE
Mes compétences s'arrêtent là, je ne connais pas assez postgres pour corriger ce problème de «relation».
Pour info, j'ai le même résultat en exécutant le script en tant qu'utilisateur postgres…
Bonne journée,
Raphux
sam. oct. 15, 2011 5:10 pm
Voici la stacktrace quand je lance openconcerto après l'installation décrite ci-dessus :
ERROR: null value in column "UNDEFINED_ID" violates not-null constraint
	at org.openconcerto.utils.ExceptionHandler.die(ExceptionHandler.java:87)
	at org.openconcerto.erp.config.Gestion.main(Gestion.java:214)
Caused by: org.postgresql.util.PSQLException: ERROR: null value in column "UNDEFINED_ID" violates not-null constraint
	at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2102)
	at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1835)
	at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:257)
	at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:500)
	at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:374)
	at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:366)
	at org.openconcerto.sql.model.SQLRowValues$9.handle(SQLRowValues.java:1568)
	at org.openconcerto.sql.model.SQLRowValues$9.handle(SQLRowValues.java:1)
	at org.openconcerto.sql.utils.SQLUtils$2.handle(SQLUtils.java:85)
	at org.openconcerto.sql.model.SQLDataSource.useConnection(SQLDataSource.java:657)
	at org.openconcerto.sql.utils.SQLUtils.executeAtomic(SQLUtils.java:66)
	at org.openconcerto.sql.model.SQLRowValues.insert(SQLRowValues.java:1547)
	at org.openconcerto.sql.model.SQLRowValues.insertCount(SQLRowValues.java:1537)
	at org.openconcerto.sql.model.SQLTable.setUndefID(SQLTable.java:140)
	at org.openconcerto.sql.preferences.SQLPreferences$1.create(SQLPreferences.java:84)
	at org.openconcerto.sql.utils.SQLUtils$1.handle(SQLUtils.java:49)
	at org.openconcerto.sql.utils.SQLUtils.executeAtomic(SQLUtils.java:46)
	at org.openconcerto.sql.preferences.SQLPreferences.getPrefTable(SQLPreferences.java:59)
	at org.openconcerto.erp.config.Gestion.main(Gestion.java:211)
L'outil de configuration ne signal aucun problème («Connexion réussie sur la base OpenConcerto»).
sam. oct. 15, 2011 6:51 pm
Pas vu de problème avec ce dump ici... vous utilisez PostgreSQL 8.4 ?
Le logiciel est capable de mettre à jour depuis les anciens dumps.
On ne va pas tarder à fournir un script pour l'install automatique.
Raphux
sam. oct. 15, 2011 7:14 pm
Salut Guillaume,
nope, postgres9.1.
Il y a vraiment un caractère invisible et néfaste dans le SQL fournit sur la page de téléchargement :
raphux@briareos2 ~ $ cd /tmp/
raphux@briareos2 /tmp $ wget http://www.openconcerto.org/fr/telechargement/OpenConcerto-sql.zip--2011-10-15 20:58:09--  http://www.openconcerto.org/fr/telechargement/OpenConcerto-sql.zip
Résolution de www.openconcerto.org... 213.186.33.17
Connexion vers www.openconcerto.org|213.186.33.17|:80...connecté.
requête HTTP transmise, en attente de la réponse...200 OK
Longueur: 605858 (592K) [application/zip]
Sauvegarde en : «OpenConcerto-sql.zip»
100%[=============================================================================>] 605 858     2,02M/s   ds 0,3s
2011-10-15 20:58:09 (2,02 MB/s) - «OpenConcerto-sql.zip» sauvegardé [605858/605858]
md5sum du zip téléchargé (qu'on soit sûr de parler du même):
raphux@briareos2 /tmp $ md5sum OpenConcerto-sql.zip
ea730b26d128e624c15d96702f49aaf2  OpenConcerto-sql.zip
Je le décompresse :
raphux@briareos2 /tmp $ unzip OpenConcerto-sql.zip
Archive:  OpenConcerto-sql.zip
  inflating: openconcerto.sql
Re- checksum pour le SQL décompressé :
raphux@briareos2 /tmp $ md5sum openconcerto.sql
3821b38a554ab4cf90a97ad8edc973ad  openconcerto.sql
Et là, vérification du caractère invisible :
raphux@briareos2 /tmp $ cat -e openconcerto.sql | head
-- Dependencies: 6$
Ce M-oM-;M-? avant CREATE SCHEMA "Common"; n'est pas normal. Tu devrais constater le même comportement, même avec pg 8.4 (je ferai un test avec une telle version si tu veux, mais je doute que cela ne change quoi que ce soit).
Je ne crois pas avoir fait d'erreur dans le processus de préparation et d'injection, j'ai été regardé dans les script shell que tu as proposé pour des versions beta (http://www.openconcerto.org/fr/beta5/install-1.1b5.sh) pour être sûr que je n'oubliais pas quelque chose.
Si ce n'était pas clair dans le premier post, je pars d'une fresh install (je drop la base entre chaque tentative d'installation pour être sûr de repartir d'un socle vierge).
Bon week!
sam. oct. 15, 2011 7:24 pm
Ok, tout va bien... :ugeek:
C'est juste le lien sur le site qui pointe sur le dump du 1.0...
Le bon lien est http://openconcerto.org/fr/telechargeme ... .1.sql.zip
Le temps de prendre la main sur un PC du boulot et je corrige le site.
Merci pour le feedback.
Raphux
sam. oct. 15, 2011 8:00 pm
Yes! C'est beaucoup mieux. :)
Merci pour ta forte réactivité!
À bientôt,
dim. oct. 16, 2011 11:58 am
J'ai une erreur avec le nouveau dump du lien ci-dessus :
[Le bon lien est http://openconcerto.org/fr/telechargeme ... .1.sql.zip]
[ERROR ] 24911.0: syntax error, unexpected INTEGER VALUE
J'ai installé PostGreSql 9.1.
Les anciens dumps s'effectuent sans erreurs.
Raphux
dim. oct. 16, 2011 12:11 pm
Tu peux détailler ta procédure d'injection STP?
dim. oct. 16, 2011 12:29 pm
Hello
C'est sympa d'être sur le coup!
  • pgadmin
    Creation Nouvelle base OpenConcerto avec tous les droits
    Bouton SQL
    Ouverture du fichier dump
    Bouton "Executer PgScript"
Ca s'arrête à la ligne indiquée qui est :
COPY "ACCES_SOCIETE" ("ID", "ID_USER_COMMON", "ID_SOCIETE_COMMON", "ARCHIVE", "ORDRE") FROM stdin;
1 1 1 0 0.00000000
C'est tout. Je ne m'y connait pas en SQL pour debugger.
Je rappelle que mes anciens dumps fonctionnent!
dim. oct. 16, 2011 1:16 pm
L'installation sous Linux (Ubuntu 11.04) est testée avec:
wget http://openconcerto.org/fr/telechargement/install-1.1.sh
bash install-1.1.sh
L'injection SQL est réalisée avec la commande: psql OpenConcerto < openconcerto-1.1.sql
Le dump de la 1.1 est différent des anciens, nous utilisons l'insertion des données par bloc
ce qui réduit considérablement le temps d'installation (qui est désormais de moins de 15s sur un serveur standard).
Je ne suis pas sûr que toutes les versions de pgAdmin soient capables de prendre ce SQL en entrée.
Préférez donc la ligne de commande.
[PS: La version 1.1 est capable de mettre à jour les anciennes versions]
