Personnalisation des modèles
Calas
mer. févr. 07, 2018 9:14 am
Je suis en train de mettre enlace OpenConcerto en version Mac monoposte.
Le logiciel refuse la modification des modèles et affiche ce message d'erreur :
Copie impossible
at java.awt.EventDispatchThread.processException(EventDispatchThread.java:223)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:215)
Caused by: java.lang.IllegalStateException: Copie impossible
at org.openconcerto.erp.generationDoc.DefaultLocalTemplateProvider.unSync(DefaultLocalTemplateProvider.java:116)
at org.openconcerto.erp.preferences.TemplateTableModel.unsync(TemplateTableModel.java:78)
at org.openconcerto.erp.preferences.TemplatePreferencePanel.modifyTemplate(TemplatePreferencePanel.java:327)
at org.openconcerto.erp.preferences.TemplatePreferencePanel$5.actionPerformed(TemplatePreferencePanel.java:233)
at java.awt.Container.processEvent(Container.java:2237)
at java.awt.Container.dispatchEventImpl(Container.java:2295)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4889)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4526)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4467)
at java.awt.Container.dispatchEventImpl(Container.java:2281)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:90)
... 5 more
Caused by: java.io.FileNotFoundException: ../../../../../../../../../../../../Users/catherinelasnon/Documents/OpenConcerto/La Bauche-50/local_VenteFacture.ods (Read-only file system)
at java.io.FileOutputStream.open0(Native Method)
at java.io.FileOutputStream.open(FileOutputStream.java:270)
at java.io.FileOutputStream.<init>(FileOutputStream.java:213)
at java.io.FileOutputStream.<init>(FileOutputStream.java:162)
at org.openconcerto.utils.FileUtils.copyFile(FileUtils.java:393)
at org.openconcerto.utils.FileUtils.copyFile(FileUtils.java:377)
at org.openconcerto.erp.generationDoc.DefaultLocalTemplateProvider.unSync(DefaultLocalTemplateProvider.java:113)
... 39 more
Merci d'avance pour votre aide.
mer. févr. 07, 2018 9:50 am
A priori le dossier dans lequel se trouve vos modèles est en lecture seule, à tout hasard, est ce que vous utilisez OpenConcerto à partir d'une session autre que celle de l'utilisateur "catherinelasnon" ? Si c'est le cas, mettez vos modèle dans un répertoire partagé entre les différentes session de l'ordinateur.
Calas
lun. févr. 12, 2018 3:14 pm
Merci pour votre réponse.
J'utilise bien OpenCOncerto depuis la session "catherinelasnon".
J'ai essayé de mettre les modèles dans un répertoire partage, mais le problème est resté identique.
C LASNON
lun. févr. 12, 2018 7:52 pm
Je n’avais pas vu que vous étiez sous Mac OS X, bien que personnellement je lui trouve de grandes qualités, le mode sandbox compliqué un peu les choses. L’avez vous installé dans le répertoire « Applications » ? Si oui, vous devez mettre les templates dans le répertoire d’OC pour être conforme avec la sandbox (une application ne peux interagir qu’avec les documents contenus dans son répertoire).
Calas
mar. févr. 13, 2018 11:22 am
Je suis désolée et me sens vraiment empotée.... Mais quel que soit l'emplacement des templates, le résultat est le même !
Calas
lun. mars 05, 2018 3:17 pm
Mon dernier message datant du 12 février n'a obtenu aucune réponse.
Le logiciel Open Concerto est parfaitement inutilisable sur mon iMac, de très nombreuses fonctions sont défaillantes, et le manuel facturé 79 € n'est d'aucune utilité pour résoudre ces nombreux problèmes.
Je suis évidemment très déçue !
C LASNON
mar. mars 06, 2018 10:05 am
Les rédacteurs du manuel ne peuvent pas anticiper tous les problèmes des mise à jour d'Apple...
Concernant votre problème, il s'agit d'un problème de droits pour l'accès au dossier /Users/catherinelasnon/Documents/OpenConcerto/La Bauche-50/
Il me semble que si l'on configure les documents sur iCloud, macOS bloque le dossier /Users/catherinelasnon/Documents/ . Il peut y avoir d'autres causes, sans l'accès à votre ordinateur, impossible de vous aider plus.
Bref, le plus simple pour vous est de ne pas passer par le menu des modèles dans le logiciel, et de modifier directement les modèles depuis le finder, cad d'ouvrir et de modifier directement les fichiers dans le dossier que vous avez précisé dans OpenConcerto.
