Problème de classes incluses dans OpenConcerto-Caisse.jar ?
edith
ven. août 19, 2011 7:38 am
Lorsque j'utilise le module de caisse, la clôture de la caisse ne s'effectue pas correctement, une exception est levée :
Exception in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError: org/openconcerto/erp/generationEcritures/GenerationMvtTicketCaisse
	at org.openconcerto.erp.core.sales.pos.Caisse.commitAll(Caisse.java:204)
	at org.openconcerto.erp.core.sales.pos.ui.CaisseMenuPanel.valueChanged(CaisseMenuPanel.java:104)
	at javax.swing.DefaultListSelectionModel.fireValueChanged(DefaultListSelectionModel.java:167)
	at javax.swing.DefaultListSelectionModel.fireValueChanged(DefaultListSelectionModel.java:137)
	at javax.swing.DefaultListSelectionModel.setValueIsAdjusting(DefaultListSelectionModel.java:668)
	at javax.swing.JList.setValueIsAdjusting(JList.java:2110)
	at javax.swing.plaf.basic.BasicListUI$Handler.mouseReleased(BasicListUI.java:2784)
	at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:273)
	at java.awt.Component.processMouseEvent(Component.java:6288)
	at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
	at java.awt.Component.processEvent(Component.java:6053)
	at java.awt.Container.processEvent(Container.java:2041)
	at java.awt.Component.dispatchEventImpl(Component.java:4651)
	at java.awt.Container.dispatchEventImpl(Container.java:2099)
	at java.awt.Component.dispatchEvent(Component.java:4481)
	at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4577)
	at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4238)
	at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168)
	at java.awt.Container.dispatchEventImpl(Container.java:2085)
	at java.awt.Window.dispatchEventImpl(Window.java:2478)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:643)
	at java.awt.EventQueue$1.run(EventQueue.java:602)
	at java.awt.EventQueue$1.run(EventQueue.java:600)
	at java.awt.EventQueue$2.run(EventQueue.java:616)
	at java.awt.EventQueue$2.run(EventQueue.java:614)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:613)
En regardant dans le jar du module, il se trouve que le package org/openconcerto/erp/generationEcritures n'en fait effectivement pas parti. Serait-ce un oubli ?
ven. août 19, 2011 10:22 am
Effectivement, bug dans le build à l'optimisation du jar...
Nous n'allons pas tarder à donner l'url de la version final 1.1 (RC1) qui corrigera pas mal de choses!
C'est prévu pour aujourd'hui ou lundi dans le pire des cas.
