societe disparue
fabrice74
lun. déc. 04, 2017 2:25 pm
bonjour
apres avoir mis a jour mon mac sur high sierra j ai du recharger la version oc 1.5.1
depuis impossible d ouvrir open concerto et de retrouver ma societe j ai ce message d erreur:
ncaughtException on thread Thread[main,5,main]
java.util.concurrent.ExecutionException: java.lang.IllegalStateException: Impossible d'obtenir une connexion sur jdbc:h2:file:/Users/imac/Library/OpenConcerto/DBData/OpenConcerto;DATABASE_TO_UPPER=false
at java.lang.Thread.dispatchUncaughtException(Thread.java:1959)
Caused by: java.lang.IllegalStateException: java.util.concurrent.ExecutionException: java.lang.IllegalStateException: Impossible d'obtenir une connexion sur jdbc:h2:file:/Users/imac/Library/OpenConcerto/DBData/OpenConcerto;DATABASE_TO_UPPER=false
Caused by: java.util.concurrent.ExecutionException: java.lang.IllegalStateException: Impossible d'obtenir une connexion sur jdbc:h2:file:/Users/imac/Library/OpenConcerto/DBData/OpenConcerto;DATABASE_TO_UPPER=false
at java.util.concurrent.FutureTask.get(FutureTask.java:192)
... 2 more
Caused by: java.lang.IllegalStateException: Impossible d'obtenir une connexion sur jdbc:h2:file:/Users/imac/Library/OpenConcerto/DBData/OpenConcerto;DATABASE_TO_UPPER=false
... 2 more
Caused by: org.h2.jdbc.JdbcSQLException: General error: "java.lang.RuntimeException: rowcount remaining=1 SYS" [50000-175]
at org.h2.engine.Database.openDatabase(Database.java:274)
... 32 more
Caused by: java.lang.RuntimeException: rowcount remaining=1 SYS
at org.h2.message.DbException.throwInternalError(DbException.java:231)
at org.h2.table.RegularTable.addIndex(RegularTable.java:272)
at org.h2.engine.Database.open(Database.java:673)
... 49 more
si on pouvais m aider svp
lun. déc. 04, 2017 3:01 pm
C'est typique d'un fichier de base de données crashé.
