Problème MàJ 1.5b4 - erreur modules au chargement
Fabien38
ven. juin 30, 2017 2:29 pm
Je suis passé de la vrsion officiel 1.4.2 à la version 1.5b4 ce jour.
Nous utilisons le cloud d'ILM.
- Installation de 1.5b4 en multiposte
- Mise à jour de la base
- Lancement d'Open Concerto
- Erreur suivante:
class org.openconcerto.modules.timetracking.element.ProjectTimeTrackingSQLElement overrides final method createTableSource.()Lorg/openconcerto/sql/view/list/SQLTableModelSourceOnline;
at org.openconcerto.erp.action.NouvelleConnexionAction$3.run(NouvelleConnexionAction.java:360)
Caused by: java.lang.VerifyError: class org.openconcerto.modules.timetracking.element.ProjectTimeTrackingSQLElement overrides final method createTableSource.()Lorg/openconcerto/sql/view/list/SQLTableModelSourceOnline;
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$100(Unknown Source)
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at org.openconcerto.erp.modules.JarModuleFactory$ModuleClassLoader.loadClass(JarModuleFactory.java:115)
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.getConstructor(Unknown Source)
at org.openconcerto.erp.modules.ModuleFactory.createModule(ModuleFactory.java:137)
at org.openconcerto.erp.modules.JarModuleFactory.createModule(JarModuleFactory.java:162)
at org.openconcerto.erp.modules.ModuleManager.applyChange(ModuleManager.java:1596)
at org.openconcerto.erp.modules.ModuleManager.createModules(ModuleManager.java:1467)
at org.openconcerto.erp.modules.ModuleManager.createModules(ModuleManager.java:1439)
at org.openconcerto.erp.modules.ModuleManager.init(ModuleManager.java:553)
at org.openconcerto.erp.action.NouvelleConnexionAction$1.run(NouvelleConnexionAction.java:151)
at org.openconcerto.sql.ui.ConnexionPanel.connect(ConnexionPanel.java:475)
at org.openconcerto.sql.ui.ConnexionPanel.access$4(ConnexionPanel.java:448)
at org.openconcerto.sql.ui.ConnexionPanel$7.run(ConnexionPanel.java:403)
Le module "gestion des temps par projet" est pourtant installé sur le poste et sur le serveur.
Je ne peux donc pas lancer OC ce qui est très problématique.
Auriez-vous une solution à me proposer ?
Fabien
ven. juin 30, 2017 2:37 pm
Bonjour Fabien,
Généralement ce n'est pas une bonne idée d'utiliser une version beta en production, ces versions comportent toujours quelques bugs et sont destinées à effectuer des tests comme indiqué.
Pour ce qui est de votre problème, il s'y rapporte justement puisque dans cette version, le support des modules n'est pas vraiment stable et que certains de ces modules ne sont pas compatibles.
Je vous conseille de revenir sur la version 1.4.2 et d'attendre que la version 1.5 soit libérée (je pense aujourd'hui ou ce lundi normalement).
occalp
ven. juin 30, 2017 2:58 pm
Bonjour Fabien,
Si vous n'utilisez pas ce module désintallez le ou désactiver le. Votre problème sera résolu.
Bien cordialement,
ven. juin 30, 2017 3:00 pm
Votre module est fait pour la version 1.4.x, attendez juste quelques heures, ne bricolez pas,
vous pourrez mettre à jour en 1.5 et installer le nouveau module.
Fabien38
ven. juin 30, 2017 3:26 pm
Merci à tous, je vais attendre quelques heures la version définitive alors ;-)
En espérant que lundi les choses soient résolues.
Pour ce qui est de desinstaller le module, la version 1.5B4 le requiert semble t'il et je m'en sert aussi.
J'ai essayé de revenir à 1.4.2 mais sans véritable succès avec toujours des problèmes de modules.
Bon WE à tous !
Fabien
Fabien38
dim. juil. 02, 2017 5:05 pm
Version 1.5 en place, base de données mise à jour et...
Et même problème:
at org.openconcerto.erp.action.NouvelleConnexionAction$3.run(NouvelleConnexionAction.java:361)
OC indique que le module est requis. Si j'essaye de la désinstaller j'ai également une erreur.
Auriez-vous une solution ?
dim. juil. 02, 2017 6:41 pm
re-téléchargez le module timetracking.
