Erreur accès "sociétés"
caubey
mar. sept. 20, 2016 10:59 am
J'ai l'erreur suivante lorsque je souhaite accéder aux détails d'une société :
Erreur d'initialisation
unknown field ORG_PROTECTION_SOCIAL_ID in SOCIETE_COMMON. The table SOCIETE_COMMON contains the followins fields: [ID, DATABASE_NAME, NOM, NUM_SIRET, NUM_NII, NUM_APE, ID_EXERCICE_COMMON, NUM_TEL, NUM_FAX, MAIL, ID_ADRESSE_COMMON, TYPE, ORDRE, ARCHIVE, NUMERO_URSSAF, RCS, CAPITAL, ID_DEVISE]
	at org.openconcerto.sql.view.EditPanel.<init>(EditPanel.java:212)
	at org.openconcerto.sql.view.EditPanel.<init>(EditPanel.java:142)
	at org.openconcerto.sql.view.ListeAddPanel.getEditFrame(ListeAddPanel.java:82)
	at org.openconcerto.sql.view.ListeAddPanel.handleAction(ListeAddPanel.java:62)
	at org.openconcerto.sql.view.IListPanel.actionPerformed(IListPanel.java:459)
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76)
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86)
Caused by: java.lang.IllegalArgumentException: unknown field ORG_PROTECTION_SOCIAL_ID in SOCIETE_COMMON. The table SOCIETE_COMMON contains the followins fields: [ID, DATABASE_NAME, NOM, NUM_SIRET, NUM_NII, NUM_APE, ID_EXERCICE_COMMON, NUM_TEL, NUM_FAX, MAIL, ID_ADRESSE_COMMON, TYPE, ORDRE, ARCHIVE, NUMERO_URSSAF, RCS, CAPITAL, ID_DEVISE]
	at org.openconcerto.sql.model.SQLTable.getField(SQLTable.java:917)
	at org.openconcerto.sql.element.BaseSQLComponent.getField(BaseSQLComponent.java:177)
	at org.openconcerto.sql.element.BaseSQLComponent.addView(BaseSQLComponent.java:277)
	at org.openconcerto.sql.element.BaseSQLComponent.addView(BaseSQLComponent.java:269)
	at org.openconcerto.erp.core.common.component.SocieteCommonSQLElement$1.addViews(SocieteCommonSQLElement.java:237)
	at org.openconcerto.sql.element.SQLComponent.uiInit(SQLComponent.java:209)
	at org.openconcerto.sql.view.EditPanel.<init>(EditPanel.java:205)
	... 42 more
Je suis sous mac Os 10.11.6 avec Openconcerto 1.4.2
Je penche vraiment sur un gros bug de java sur ma machine (erreurs d'import/export, modules qui n'apparaissent pas ...). Pour info, OpenConcerto m'indique cette version : Version 1.8.0_101-b13
olivierGBS
mar. sept. 20, 2016 12:10 pm
est ce que vous avez mis à jour la base de donnée via l'outil de configuration d'openconcerto ?
Bien cordialement,
caubey
mar. sept. 20, 2016 1:40 pm
Bonjour OlivierGBS
Merci pour votre réponse. Oui je l'ai fait plusieurs fois, et malheureusement j'ai un autre soucis, je ne peux plus accéder à ma base clients :
unknown field OBSOLETE in CLIENT. The table CLIENT contains the followins fields: [ID, FORME_JURIDIQUE, NOM, CODE, TEL, MAIL, FAX, NUMERO_TVA, ID_ADRESSE, ARCHIVE, ORDRE, RESPONSABLE, ID_ADRESSE_L, INFOS, TEL_P, RESPONSABLE_TECH, TEL_P_TECH, TEL_TECH, MAIL_TECH, RESPONSABLE_COM, TEL_P_COM, MAIL_COM, TEL_COM, ID_MODE_REGLEMENT, ID_ADRESSE_F, FAX_TECH, FAX_COM, ID_COMPTE_PCE, SIRET, RIB, MARCHE_PUBLIC, MARCHE_PRIVE, AFFACTURAGE, MAX_FACTURE, COMPTANT, COMPTE_CLIENT_AUTO, MODIFICATION_DATE, ID_USER_COMMON_CREATE, ID_USER_COMMON_MODIFY, CREATION_DATE, ID_TARIF, ID_PAYS, ID_LANGUE, ID_DEVISE, BLOQUE_LIVRAISON, BLOQUE, ID_COMPTE_PCE_SERVICE, ID_COMPTE_PCE_PRODUIT, ENCOURS_MAX, CATEGORIES, NOTE_FINANCIERE, CENTRE_GESTION, METHODE_RELANCE, SITE_INTERNET, GROUPE, ID_COMMERCIAL, TIMBRE_FISCAL]
	at java.awt.EventDispatchThread.processException(EventDispatchThread.java:223)
	at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:215)
Caused by: java.lang.IllegalArgumentException: unknown field OBSOLETE in CLIENT. The table CLIENT contains the followins fields: [ID, FORME_JURIDIQUE, NOM, CODE, TEL, MAIL, FAX, NUMERO_TVA, ID_ADRESSE, ARCHIVE, ORDRE, RESPONSABLE, ID_ADRESSE_L, INFOS, TEL_P, RESPONSABLE_TECH, TEL_P_TECH, TEL_TECH, MAIL_TECH, RESPONSABLE_COM, TEL_P_COM, MAIL_COM, TEL_COM, ID_MODE_REGLEMENT, ID_ADRESSE_F, FAX_TECH, FAX_COM, ID_COMPTE_PCE, SIRET, RIB, MARCHE_PUBLIC, MARCHE_PRIVE, AFFACTURAGE, MAX_FACTURE, COMPTANT, COMPTE_CLIENT_AUTO, MODIFICATION_DATE, ID_USER_COMMON_CREATE, ID_USER_COMMON_MODIFY, CREATION_DATE, ID_TARIF, ID_PAYS, ID_LANGUE, ID_DEVISE, BLOQUE_LIVRAISON, BLOQUE, ID_COMPTE_PCE_SERVICE, ID_COMPTE_PCE_PRODUIT, ENCOURS_MAX, CATEGORIES, NOTE_FINANCIERE, CENTRE_GESTION, METHODE_RELANCE, SITE_INTERNET, GROUPE, ID_COMMERCIAL, TIMBRE_FISCAL]
	at org.openconcerto.sql.request.ListSQLRequest.<init>(ListSQLRequest.java:57)
	at org.openconcerto.sql.element.SQLElement.instantiateListRequest(SQLElement.java:1645)
	at org.openconcerto.sql.element.SQLElement.createListRequest(SQLElement.java:1628)
	at org.openconcerto.sql.element.SQLElement.createListRequest(SQLElement.java:1615)
	at org.openconcerto.sql.element.SQLElement.createListRequest(SQLElement.java:1611)
	at org.openconcerto.sql.element.SQLElement.createTableSource(SQLElement.java:1714)
	at org.openconcerto.sql.element.SQLElement.createAndInitTableSource(SQLElement.java:1689)
	at org.openconcerto.sql.element.SQLElement.getTableSource(SQLElement.java:1675)
	at org.openconcerto.erp.core.customerrelationship.customer.action.ListeDesClientsAction.getTableSource(ListeDesClientsAction.java:47)
	at org.openconcerto.erp.core.customerrelationship.customer.action.ListeDesClientsAction.createFrame(ListeDesClientsAction.java:54)
	at javax.swing.AbstractButton.doClick(AbstractButton.java:376)
	at com.apple.laf.ScreenMenuItem.actionPerformed(ScreenMenuItem.java:125)
	at java.awt.MenuItem.processActionEvent(MenuItem.java:669)
	at java.awt.MenuItem.processEvent(MenuItem.java:628)
	at java.awt.MenuComponent.dispatchEventImpl(MenuComponent.java:351)
	at java.awt.MenuComponent.dispatchEvent(MenuComponent.java:339)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:761)
	... 5 more
mar. sept. 20, 2016 5:50 pm
OpenConcerto se plaint de ne pas trouver le champs "OBSOLETE" dans la table "CLIENT" ce qui vous empeche d'accéder à vos clients.
La raison est simple, vous utilisez OpenConcerto 1.4.2 et votre base de données n'est pas à jour.
Mettez à jour LA BASE DE DONNEES avec la dernière version!
caubey
ven. sept. 23, 2016 12:23 pm
J'ai finalement réussi à relancer le logiciel, en passant par un autre ordinateur ; par contre j'ai toujours mon soucis d'importation.
Erreur pendant l'importation
Index: 6, Size: 6
Caused by: java.lang.IndexOutOfBoundsException: Index: 6, Size: 6
	at java.util.ArrayList.rangeCheck(ArrayList.java:653)
	at java.util.ArrayList.get(ArrayList.java:429)
	at org.openconcerto.erp.importer.ArrayTableModel.getValueAt(ArrayTableModel.java:95)
	at org.openconcerto.erp.core.finance.accounting.ui.ImportEcriturePanel.importData(ImportEcriturePanel.java:206)
	... 7 more
ven. sept. 23, 2016 2:33 pm
Vous n'avez pas respecté le format de fichier... il manque une colonne...
