Openconcerto Multiposte MAC OSX 10.8
trickscenique
mer. mai 11, 2016 1:28 pm
Je n'arrive pas à configurer un de mes postes clients qui tourne sous MAC OSX 10.8.5
J'essaye d'installer la version 1.4.1 d'openconcerto
J'obtiens l'erreur suivante
Impossible de se connecter à la base de données.
Vérifiez votre connexion.
Connection failed
org.openconcerto.utils.ExceptionHandler: Impossible de se connecter à la base de données.
	at org.openconcerto.erp.config.ComptaPropsConfiguration.createServer(ComptaPropsConfiguration.java:1151)
	at org.openconcerto.sql.PropsConfiguration.getServer(PropsConfiguration.java:1131)
	at org.openconcerto.erp.config.ComptaPropsConfiguration.createSystemRoot(ComptaPropsConfiguration.java:672)
	at org.openconcerto.sql.PropsConfiguration.getSystemRoot(PropsConfiguration.java:1096)
	at org.openconcerto.erp.config.ServerFinderConfig.test(ServerFinderConfig.java:166)
	at org.openconcerto.erp.config.ServerFinderPanel$8$1.doInBackground(ServerFinderPanel.java:553)
	at org.openconcerto.erp.config.ServerFinderPanel$8$1.doInBackground(ServerFinderPanel.java:1)
	at javax.swing.SwingWorker$1.call(SwingWorker.java:296)
	at java.util.concurrent.FutureTask.run(FutureTask.java:262)
	at javax.swing.SwingWorker.run(SwingWorker.java:335)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
Caused by: java.lang.IllegalStateException: Connection failed
	at org.openconcerto.sql.PropsConfiguration.openSSLConnection(PropsConfiguration.java:627)
	at org.openconcerto.sql.PropsConfiguration.createServer(PropsConfiguration.java:541)
	at org.openconcerto.erp.config.ComptaPropsConfiguration.createServer(ComptaPropsConfiguration.java:1148)
	... 13 more
Caused by: com.jcraft.jsch.JSchException: Algorithm negotiation fail
	at com.jcraft.jsch.Session.receive_kexinit(Session.java:583)
	at com.jcraft.jsch.Session.connect(Session.java:320)
	at org.openconcerto.sql.PropsConfiguration.openSSLConnection(PropsConfiguration.java:622)
	... 15 more
J'utilise le même fichier de configuration que sur mes postes linux.
#OpenConcerto
#Sat Apr 30 16:22:50 CEST 2016
server.wan.only=true
server.driver=postgresql
base.root=Common
server.wan.port=MONPORTSSH
server.wan.password=MONMOTDEPASSESSH
server.wan.user=openconcerto
systemRoot=OpenConcerto
\u00EF\u00BB\u00BF\#OpenConcerto=
customer=Gestion_Default
server.ip=IPLOCALEDUSERVEUR\:PORTPOSTGRESQL
server.wan.addr=IPDUSERVEUR
Est-ce que vous pourriez m'éclairer ?
Merci beaucoup !
Nassim Ourami
http://www.trickscenique.com
mer. mai 11, 2016 4:51 pm
regardez vos logs de ssh, il y a surement une configuration à changer sur le serveur opensssh pour que le Mac puisse négocier un algorithme valide.
trickscenique
ven. mai 13, 2016 3:56 pm
Merci pour votre retour, je regarde de suite.
Nassim Ourami
