Erreur de connexion à la base - jdbc
Qualitec
jeu. juin 18, 2015 7:34 am
J'utilise Openconcerto depuis bientôt un an et hier impossible d'ouvrir le logiciel, j'ai le message d'erreur suivant :
Merci d'avance pour votre aide.
Cdlt
Francis
Impossible d'obtenir une connexion sur jdbc:h2:file:C:\Documents and Settings\Caroline\.java\ilm\sql-config\OpenConcerto\DBData/OpenConcerto: File corrupted while reading record: "[4848] stream data key:273 pos:11 remaining:0". Possible solution: use the recovery tool [90030-175]
at org.openconcerto.erp.config.Gestion.main(Gestion.java:327)
Caused by: java.lang.IllegalStateException: Impossible d'obtenir une connexion sur jdbc:h2:file:C:\Documents and Settings\Caroline\.java\ilm\sql-config\OpenConcerto\DBData/OpenConcerto: File corrupted while reading record: "[4848] stream data key:273 pos:11 remaining:0". Possible solution: use the recovery tool [90030-175]
at org.openconcerto.sql.model.SQLDataSource.getRawConnection(SQLDataSource.java:1194)
at org.openconcerto.sql.model.SQLDataSource.borrowConnection(SQLDataSource.java:1129)
at org.openconcerto.sql.model.SQLDataSource.getNewConnection(SQLDataSource.java:1111)
at org.openconcerto.sql.model.SQLDataSource$QueryInfo.<init>(SQLDataSource.java:611)
at org.openconcerto.sql.model.SQLDataSource.execute(SQLDataSource.java:519)
at org.openconcerto.sql.model.SQLDataSource.getSchema(SQLDataSource.java:1660)
at org.openconcerto.sql.model.SQLDataSource.getSchema(SQLDataSource.java:1642)
at org.openconcerto.sql.model.DBSystemRoot.setRootPathFromDS(DBSystemRoot.java:603)
at org.openconcerto.sql.model.DBSystemRoot.setDS(DBSystemRoot.java:599)
at org.openconcerto.sql.model.SQLBase.<init>(SQLBase.java:138)
at org.openconcerto.sql.model.SQLSyntax.createBase(SQLSyntax.java:800)
at org.openconcerto.sql.model.SQLServer.createBase(SQLServer.java:417)
at org.openconcerto.sql.model.SQLServer.getBase(SQLServer.java:405)
at org.openconcerto.sql.model.SQLServer.createSystemRoot(SQLServer.java:464)
at org.openconcerto.sql.model.SQLServer.getSystemRoot(SQLServer.java:442)
at org.openconcerto.sql.model.SQLServer.getSystemRoot(SQLServer.java:422)
at org.openconcerto.erp.config.ComptaPropsConfiguration.createSystemRoot(ComptaPropsConfiguration.java:602)
at org.openconcerto.sql.PropsConfiguration.getSystemRoot(PropsConfiguration.java:1095)
at org.openconcerto.erp.config.Gestion.main(Gestion.java:297)
Caused by: org.h2.jdbc.JdbcSQLException: File corrupted while reading record: "[4848] stream data key:273 pos:11 remaining:0". Possible solution: use the recovery tool [90030-175]
at org.openconcerto.sql.model.SQLDataSource$2.makeObject(SQLDataSource.java:1375)
at org.openconcerto.sql.model.SQLDataSource.createPoolableConnectionFactory(SQLDataSource.java:1390)
at org.openconcerto.sql.model.SQLDataSource.getRawConnection(SQLDataSource.java:1177)
... 20 more
jeu. juin 18, 2015 12:46 pm
Le fichier de votre base de données est corrompu, causes possibles :
- virus
- antivirus
- mémoire défectueuse
- disque dur défectueux
- redémarrage du PC sans avoir fermé OpenConcerto
Ce genre de soucis n'arrive pas sur le multiposte.
Sortez vos sauvegardes.
