Bonsoir à tous,
J'ai ce message d'erreur qui apparaît depuis ce soir :
Quelqu'un peut m'aider ?
D'avance merci,
Cannot set value of org.openconcerto.ui.valuewrapper.ValidatedValueWrapper@4cf5489e to 0 (from |ARTICLE.PA_HT|)
Caused by: java.lang.IllegalArgumentException: Cannot set value of org.openconcerto.ui.valuewrapper.ValidatedValueWrapper@4cf5489e to 0 (from |ARTICLE.PA_HT|)
at org.openconcerto.sql.sqlobject.itemview.VWRowItemView.show(VWRowItemView.java:130)
at org.openconcerto.sql.request.SQLRowView.select(SQLRowView.java:276)
at org.openconcerto.sql.element.BaseSQLComponent.selectDefaults(BaseSQLComponent.java:771)
at org.openconcerto.sql.element.BaseSQLComponent.select(BaseSQLComponent.java:756)
at org.openconcerto.sql.element.BaseSQLComponent.select(BaseSQLComponent.java:737)
at org.openconcerto.erp.core.sales.product.component.ReferenceArticleSQLComponent.select(ReferenceArticleSQLComponent.java:210)
at org.openconcerto.sql.element.BaseSQLComponent.resetValue(BaseSQLComponent.java:683)
at org.openconcerto.sql.view.EditPanel.resetValue(EditPanel.java:567)
at org.openconcerto.sql.view.EditFrame$3.hierarchyChanged(EditFrame.java:159)
at java.awt.Component.processHierarchyEvent(Unknown Source)
at java.awt.Window.processEvent(Unknown Source)
at java.awt.Component.createHierarchyEvents(Unknown Source)
at java.awt.Container.createHierarchyEvents(Unknown Source)
at java.awt.Window.show(Unknown Source)
at org.openconcerto.ui.FrameUtil.show(FrameUtil.java:32)
at org.openconcerto.sql.view.IListPanel.handleAction(IListPanel.java:519)
at org.openconcerto.sql.view.ListeAddPanel.handleAction(ListeAddPanel.java:65)
at org.openconcerto.erp.core.sales.product.action.ListeDesArticlesAction$2.handleAction(ListeDesArticlesAction.java:171)
at org.openconcerto.sql.view.IListPanel.actionPerformed(IListPanel.java:468)
... 6 more
Caused by: java.lang.IllegalStateException: Attempt to mutate in notification
at javax.swing.text.AbstractDocument.writeLock(Unknown Source)
at javax.swing.text.AbstractDocument.replace(Unknown Source)
at javax.swing.text.JTextComponent.setText(Unknown Source)
at org.openconcerto.erp.core.sales.product.component.ReferenceArticleSQLComponent.updatePiece(ReferenceArticleSQLComponent.java:1334)
at org.openconcerto.erp.core.sales.product.component.ReferenceArticleSQLComponent.access$16(ReferenceArticleSQLComponent.java:1329)
at org.openconcerto.erp.core.sales.product.component.ReferenceArticleSQLComponent$16.update(ReferenceArticleSQLComponent.java:1060)
at org.openconcerto.utils.text.SimpleDocumentListener.removeUpdate(SimpleDocumentListener.java:51)
at javax.swing.text.AbstractDocument.fireRemoveUpdate(Unknown Source)
at javax.swing.text.AbstractDocument.handleRemove(Unknown Source)
at javax.swing.text.AbstractDocument$DefaultFilterBypass.replace(Unknown Source)
at org.openconcerto.utils.text.DocumentFilterList$ChainedFilterBypass.replace(DocumentFilterList.java:206)
at org.openconcerto.ui.filters.FormatFilter.replace(FormatFilter.java:114)
at org.openconcerto.utils.text.DocumentFilterList$ChainedFilterBypass.replace(DocumentFilterList.java:208)
at org.openconcerto.utils.text.DocumentFilterList.replace(DocumentFilterList.java:157)
at org.openconcerto.erp.core.sales.product.component.ReferenceArticleSQLComponent$1.update(ReferenceArticleSQLComponent.java:108)
at javax.swing.text.AbstractDocument$DefaultFilterBypass.remove(Unknown Source)
at org.openconcerto.utils.text.DocumentFilterList$ChainedFilterBypass.remove(DocumentFilterList.java:194)
at javax.swing.text.DocumentFilter.remove(Unknown Source)
at org.openconcerto.utils.text.DocumentFilterList$ChainedFilterBypass.remove(DocumentFilterList.java:196)
at org.openconcerto.utils.text.DocumentFilterList.remove(DocumentFilterList.java:152)
at javax.swing.text.AbstractDocument.remove(Unknown Source)
at org.openconcerto.ui.component.IDocument.setText(IDocument.java:43)
at org.openconcerto.ui.valuewrapper.format.FilterFormatValueWrapper.setText(FilterFormatValueWrapper.java:69)
at org.openconcerto.ui.valuewrapper.format.FormatValueWrapper.setValue(FormatValueWrapper.java:183)
at org.openconcerto.ui.valuewrapper.ValidatedValueWrapper.setValue(ValidatedValueWrapper.java:166)
at org.openconcerto.sql.sqlobject.itemview.VWRowItemView.show(VWRowItemView.java:128)
... 64 more
