Erreur à la cloture de caisse
Circuit-Court
mar. juil. 11, 2017 10:09 am
J'ai une erreur qui apparait à la cloture de la caisse, la rendant impossible :
Une erreur est survenue pendant la clôture.
can't update SQLRowValues on /SAISIE_VENTE_FACTURE_ELEMENT/ : {QTE=1(class java.lang.Integer), PV_HT=8.80(class java.math.BigDecimal), T_PV_HT=8.80(class java.math.BigDecimal), T_PV_TTC=8.8000(class java.math.BigDecimal), ID_TAXE=6(class java.lang.Integer), CODE=chouguer(class java.lang.String), NOM=Chouchen Guermahia 75cl(class java.lang.String), ID_ARTICLE=125(class java.lang.Integer)} : the field ID_ARTICLE points to (ARTICLE[125])
org.openconcerto.utils.ExceptionHandler: Une erreur est survenue pendant la clôture.
at org.openconcerto.erp.core.sales.pos.POSConfiguration.commitAll(POSConfiguration.java:398)
at org.openconcerto.erp.core.sales.pos.ui.CaisseMenuPanel$2.actionPerformed(CaisseMenuPanel.java:84)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:90)
Caused by: java.lang.IllegalStateException: can't update SQLRowValues on /SAISIE_VENTE_FACTURE_ELEMENT/ : {QTE=1(class java.lang.Integer), PV_HT=8.80(class java.math.BigDecimal), T_PV_HT=8.80(class java.math.BigDecimal), T_PV_TTC=8.8000(class java.math.BigDecimal), ID_TAXE=6(class java.lang.Integer), CODE=chouguer(class java.lang.String), NOM=Chouchen Guermahia 75cl(class java.lang.String), ID_ARTICLE=125(class java.lang.Integer)} : the field ID_ARTICLE points to (ARTICLE[125])
at org.openconcerto.sql.model.SQLRowValues.checkValidity(SQLRowValues.java:1771)
at org.openconcerto.sql.model.SQLRowValuesCluster.store(SQLRowValuesCluster.java:416)
at org.openconcerto.sql.model.SQLRowValuesCluster.store(SQLRowValuesCluster.java:372)
at org.openconcerto.sql.model.SQLRowValuesCluster.store(SQLRowValuesCluster.java:367)
at org.openconcerto.sql.model.SQLRowValues.store(SQLRowValues.java:1853)
at org.openconcerto.sql.model.SQLRowValues.insert(SQLRowValues.java:1833)
at org.openconcerto.erp.core.sales.pos.POSConfiguration$1.create(POSConfiguration.java:327)
at org.openconcerto.erp.core.sales.pos.POSConfiguration.commitAll(POSConfiguration.java:237)
... 37 more
J'ai vérifié le produit "Chouchen Guermahia 75cl" dont il est question mais le réglage me semble correct.
D'où ça peut venir ?
Gérald
Conceptify
mar. juil. 11, 2017 3:36 pm
On dirait bien que ça vient de l'article !
Qu'a t'il de différent par rapport aux autres si c'est le seul à déconner?
Circuit-Court
mer. juil. 19, 2017 6:22 am
Nous avons finalement trouvé :
La vendeuse a scanné cet article puis s'est aperçu que le prix n'était pas correct sur le ticket.
Elle voit ensuite que cet article était en doublon (mais avec 2 code-barre différents)
Souhaitant bien faire, elle supprime celui qu'elle estime mauvais mais c'est ce produit même qui avait été scanné dans le ticket : d'où la clôture impossible de la caisse.
Un peu tordu... mais résolu
